How to add column fields in List view - In Portal
chanikya
How to add more columns here -closed date, Created By, Opened By
Hey Chanikya,
There is no Mobile view by default for the sc_req_item table and so you have to create one using the steps below:
Steps to add mobile list view
  1. Go to System UI -> Views
  2. Find the Mobile view
  3. On the lists tab add the sc_req_item table
  4. Open the new sc_req_item sys_ui_list record
  5. Add the elements and their position as you would like them to appear.
There is no Mobile view by default for sc_req_item and so it uses the task one.
Hope this helps!
25 REPLIES 25
I became very excited when I saw this (learned something new) but unfortunately the form that pops up to be edited doesn't match the one I'm viewing...
Abdul Khan4
Mega Guru
Login to ServiceNow as Admin and go to list view for Requested Item Table.  Select view as default or Portal. See image marked 1 below. Right click on Menu header and click on configure -> List Layout. Image (Mark 2) and select required fields.
i have followed your steps but it is not working here, can you suggest me another way please
Did you check the View? List view and Portal view must be same.
Are you doing this for your personal instance? If yes, you can share the URL and password. I will fix it quickly.
