How to add to a current cart instead of new cart()
e_wilber
I have a script that works great- it copies a previous request and tosses all the RITMs into the curent user's shopping cart. The problem is, the script is deleting everything in their cart with new cart = Cart();
I found some code on the wiki (below) but it doesn't work. In fact it stops my script from copying anything to the cart at all. I did a test print on the userID and it is finding my userID and my cart, it just doesn't add items to it.
var cart = getCart();
  function getCart() {
          var cart = new GlideRecord('sc_cart');
          var userid = gs.getUserID();
          cart.addQuery('user', userid);
          cart.query();
          if (cart.next()) {
                  // we already have a cart all is well
    gs.log('found cart ' + userid);
          else {
    gs.log('new cart');
                  cart.initialize();
                  cart.user = userid;
                  cart.insert();
      return cart;
Below is the actual code I'm trying to use. Anyone see why I'm not able to keep the items in my shopping cart?
var origReq = new GlideRecord('sc_request');
origReq.addQuery('sys_id', rid);
origReq.query();
if(origReq.next()){
gs.log(cart);
cart.cart.update();
//cart.cart.special_instructions = 'PARENT:' + parentRequest.sys_id;
//cart.cart.update();
var ritm = new GlideRecord('sc_req_item');
ritm.addQuery('request', reqID);
ritm.query();
while (ritm.next()) {
// start copying the RITM vars
var oldRITM   = new GlideRecord('sc_req_item');
oldRITM.get(ritm.sys_id);
var newRITM = cart.addItem(oldRITM.cat_item, 1);
for (var varName in oldRITM.variables) {
cart.setVariable(newRITM, varName, oldRITM.variables[varName]+'');
15 REPLIES 15
kkisz
Kilo Explorer
Could you please provide a little more information on how/where to use this?
