How to auto close changes older than 30 days
05-04-2020 03:05 AM
Hi, please assist with the below script.
I tried the below code it closes changes that are new. I want to close changes that are in 'scheduled' ,'implement' and 'review' state where the planned implementation date is older than 30 days and the related
Task should be closed as well.
var gr = new GlideRecord('change_request');
gr.addQuery('u_change_phase', 3);
gr.addQuery('active', true);
gr.addQuery('opened_at', '>', gs.daysAgoStart(30));
while (gr.next()) {
gr.u_change_phase = 4;
gr.change_state = 5;
gr.active = false;
gr.update();
Change Management
05-04-2020 03:20 AM
I initially tested with 'u_change_phase' = 0, and it worked it updated all new changes but when i updated the state that i wanted it didn't work. i'm testing the changes first to see if that works.
05-04-2020 03:30 AM
So can you double check what I mentioned:
change_state
Is this a correct field?
Kind regards,
Mark
2020 ServiceNow Community MVP
2020 ServiceNow Developer MVP
