How to call a flow from another flow in ServiceNow
hemanth16
I have a catalog item one all the flow is completed I need call another flow
I am giving if condition as task is complete then start the flow
How can I add the flow ?
Any suggestions!
Thanks in Advance!!
Sai Kumar B
@hemanth16
You can't call a flow from another flow but you can call a Subflow from a flow.  Create a Subflow and call from the main flow.
Hi Sai,
Thanks for the response
while I am creating Sub flow it is asking input and output can you help me on that ? I am new for this
Thanks in Advance!!
@hemanth16 Yes, to call subflow inputs must be passed from main flow. I would suggest to refer the following learning plan it guides you how to create subflow and how to call subflow from the main flow
Creating Subflows in Flow Designer
Hi Sai,
Should I create again my flow activities in subflow ?
Thanks in advance!!
