How to call flow designer from workflow ?
Haceena Shaik
Hi all,
Is it possible to call flow designer from workflow and passing parameters from workflow to flow designer. Does Code snippet in flow designer is the only way?
Nithya
Hi @Haceena Shaik ,
 Please follow this Article : Calling Flow designer from Workflow When using both workflow and flow designer for service catalog
Also,
you can try to use executeAction(action name, inputs) from workflow run script
how to trigger flow or subflow or action from script; check below link
Scripting with Flows, Subflows, and Actions
Hi @Haceena Shaik ,
Shariq Azim
In case of Sub flow
(function() {
// ... code ...
try {
var flw = 'name_of _the_flow'
var inputs = {};
inputs['param1'] = 'value_of _param1';
inputs['param2'] = 'value_of _param2' //optional;
// Start Asynchronously: Uncomment to run in background.
/var results = sn_fd.FlowAPI.getRunner().flow('global.' + flw).inBackground().withInputs(inputs).run();
current.flow_context = results.getContextId();
} catch (ex) {
var message = ex.getMessage();
gs.error(message);
