11-28-2018 10:37 PM
Guys am trying to show `name` field from `announcement` table on html side using `<marquee></marquee>` field.
Server script:
(function() {
var announce=new GlideRecord('announcement');
announce.addQuery('active=true');
announce.query();
while(announce.next()){
data.announcement= announce.name;
console.log(data.announcement);// got data here
HTML code:
<div>
<marquee>{{data.announcement}}</marquee>
</div>
I am not getting the data on html code. What I did wrong here?
If I have multiple datas on name field how can I loop it?
11-29-2018 04:29 AM
The following code worked me for showing marquee data from array and object.
serverside:
(function() {
data.arr = [];
announce.query();
var record={};
var display_value='';
display_value = announce.getValue('name') ;
record.display_field=display_value;
data.arr.push(record);
Html side:
<div>
<marquee><b ng-repeat='val in data.arr'><label>{{val.display_field}}</label></b></marquee>
</div>
11-29-2018 01:10 AM
No its not working because 'data.announcement' is a string right? How can i call 'arr[]' from server side to client side? if we store 'arr[]' in a '$scope' ,then it will be easy to use ng-repeat right? when I tried with '$scope.val=c.arr' on client side it returns nothing.
11-29-2018 01:11 AM
Hi
In this case you can return the length of array.
11-29-2018 01:14 AM
Hi
Please post a new question as this thread is closed, also your question is new. Thanks
11-29-2018 04:29 AM
serverside:
(function() {
data.arr = [];
announce.query();
var record={};
Html side:
<div>
</div>
