How to change state of problem record to closed when it is not resolved state?
Masa4
Giga Contributor
I would like to change state to close when I get solution in the middle of supporting problem without worrying the state and processing state model.
Therefore I created the UI Action for changing state to closed.
But I get the error message and state is not changed when I click this button on the form.
ERROR MESSAGE: Invalid state transition. Can not update from state 'New' to state 'Closed' with given values.
Do you have good any ideas to implement this feature?
BR,
Then look for the entry where the table is "problem" open it; in the "State Transitions" related list pick the "Closed" state, open it and adjust "Enter Condition" to allow entering from as many states as you need to.
15 REPLIES 15
Masa4
Giga Contributor
Hi Janos,
Thanks for your comments.
OK, I will try to see the state model.
Do you know the place of the state model script?
BR,
It is not a script, it is pure configuration; look for "State Models" module in the navigator (under application "State Management").
Masa4
Giga Contributor
Hi Janos,
I did not know that!
Is the error message displayed based on that "State models" ?
BR,
Yes it is based on these settings.
If the "Enter Condition" is not fulfilled, the error will show up.
That makes it a good idea to base UI Action availability on the state model.
