How to Check if a Journal field is empty
Eli Guttman
I tried to check in a mail script and a business rule if a field of journal type is empty,
what is the best way to do it? does it different if i'm using "Journal Input" field?
thank you!
darshanr
Hi Eli,
Journal field will always be empty.
You can check with below line:
current.fieldName.getJournalEntry(-1);// It will bring all the journal entries which were added to this
If empty then no entries were added.
Using Journal Fields - ServiceNow Wiki
Please mark answer correct if it was.
Darshan
Sys ID of the record to be specific for Querying the sys_journal_field table.
Subhajit
