08-30-2022 12:31 AM
Can someone please advice, How can we check if Array if it is null or undefined in Transform map OnAfter Script?
08-30-2022 12:35 AM
you can check if array is empty
var arr = ['a','b'];
if(arr.length ==0){
// empty
08-30-2022 02:05 AM
Hi
What did you try in encodedquery?
One option is to use:
if(arr.indexOf('invalid') > -1){
//goes inside if, when invalid is present in the array arr
}else{
//when invalid is not present in the array arr
Feel free to mark correct, if your issue has been resolved, so it ends up in solved queue.
Will be helpful for others looking for the similar query.
08-30-2022 12:36 AM
Hi Ankita,
You can use the available OOB script includes JSUtil
JSUtil.isEmpty()
