How to compare string field with reference field in transform map?
02-16-2021 11:29 PM
I have a field in Excel named "Schedule" it maps with "Schedule" in cmn_schedule_span table...
so here my issue is...
Suppose in Excel If I provide like "India Schedule" while transforming it is referring to "Schedule" which is a reference field due to this my transform map is not working...
so can anyone please explain how can we compare a string with reference field in transform map
02-17-2021 07:16 AM
If the same set of data again comes then all rows of the import set should be ignored as the information is same
02-17-2021 07:26 AM
because please check the below scenarios
Schedule 1 "Indian holidays...scheduled entries are like below..
Independence day AUG15
Republic day Jan 26th
Schedule 2 "Peru Holidays"....schedule entries are like below
Independence day 28 July
So if I took the name as coalesce field then it schedules may get conflicted...because for different countries different schedules....
So earlier I took schedules as "coalesce" field but it was incorrect....so please suggest and help me ankur what field should I take as coalesce field
02-17-2021 07:29 AM
take combination of Schedule + Start + end
02-17-2021 07:44 AM
If I do like that there is one more issue ankur, because as now I am updating calender...
So at present in indian schedule be like this
Independence day Aug 15th 2020
so I need to update as
Independence day Aug 15th 2021..
If I follow as you mentioned then it will create record....but not update..
here all that I am doing is updating the calendar through transform map..for this what I did is from servicenow scheduled entries I download the excel file for one of the schedule and checked calender of the 2021 and updated in the excel, now I need to run through transform map to update it in servicenow...
Hope you will understand it clearly now
02-17-2021 09:39 AM
