‎10-08-2020 07:36 AM
‎10-08-2020 07:40 AM
Hi Praveen,
I assume you want attachment to be copied over from SC Task to RITM when attachment is added
sample BR on sys_attachment; It would be copying all attachments to RITM from SC TASK
BR: after insert on sys_attachment
Condition: current.table_name == 'sc_task'
Script:
var taskRec = new GlideRecord('sc_task');
taskRec.addQuery('sys_id', current.table_sys_id);
taskRec.query();
if(taskRec.next()){
var ritmRec = new GlideRecord('sc_req_item');
ritmRec.addQuery('sys_id',taskRec.request_item);
ritmRec.query();
if(ritmRec.next()){
GlideSysAttachment.copy('sc_task', current.table_sys_id, 'sc_req_item', ritmRec.sys_id);
‎08-31-2021 04:38 PM
Hi
I have used similar code to copy attachments from SC Task to RITM table but the problem is the attachments in the sc task are from "Attachment" variable.
So, instead of
I have used
GlideSysAttachment.copy('ZZ_YYsc_task', current.table_sys_id, 'sc_req_item', ritmRec.sys_id);
Now, attachment is getting copied from sc task to activity stream of RITM but not to the paperclip icon on the header. I want that to be attached to paperclip on the RITM table. Do you have any suggestions on this?
Also, I don't see the attachment variable on the sc task once the task is closed complete, it would be good to have it on the task even it's closed.
FYI - we are currently on Paris version and the catalog item is in a scoped application.
Kat
‎03-24-2025 07:07 AM
hi Ankur,
what is the table in the BR configuration? and what is the filter condition? thanks!!
‎03-24-2025 07:13 AM
can you post a new question for this and tag me there and share all the details as this is an old thread?
‎08-19-2025 04:37 AM
Hi!
This BR works well, but as you said, it would be copying all attachments from the SC Task to the RITM. So, if I add multiple ones, there are going to be duplicate attachments on the RITM.
Is there a way to copy only the newly added attachment, or do I have to create another BR to remove duplicate attachments?
‎08-19-2025 05:53 AM
Can you post a new question with all the details and tag me there as this is an old thread?
