How to copy attachment from sctask to ritm
Praveen94
Ankur Bawiskar
Hi Praveen,
I assume you want attachment to be copied over from SC Task to RITM when attachment is added
sample BR on sys_attachment; It would be copying all attachments to RITM from SC TASK
BR: after insert on sys_attachment
Condition: current.table_name == 'sc_task'
Script:
var taskRec = new GlideRecord('sc_task');
taskRec.addQuery('sys_id', current.table_sys_id);
taskRec.query();
if(taskRec.next()){
var ritmRec = new GlideRecord('sc_req_item');
ritmRec.addQuery('sys_id',taskRec.request_item);
ritmRec.query();
if(ritmRec.next()){
GlideSysAttachment.copy('sc_task', current.table_sys_id, 'sc_req_item', ritmRec.sys_id);
20 REPLIES 20
Hi @Ankur Bawiskar
The problem I'm having is that all attachments are copied from the SCTASK to the RITM. This means that every time I add something to the SCTASK, duplicates are created on the RITM.
If I add document 1 to the SCTASK, I get document 1 on the RITM. Now, if I add document 2 to the same SCTASK, I get document 1 twice and document 2 on the RITM.
I have a rule that prevents duplicates, but it's based on the 'table_sys_id'/'table_name'/'file_name'/'content_type'/'size_bytes' fields, which isn't perfect.
I'd like to copy only the newly added attachment to avoid any duplicates from the start. Do you know of a way to do this?
@Clement_V
Can you post a new question with all the details and tag me there as this is an old thread?
Sorry, I didn't quite understand the request.
I'll do that.
Hi Ankur,
It is attaching all the previous attachments which is there in the Task to RITM on every attachments.
so we need copy only the one attached recently..
Magali Modugno
Hey @Ankur Bawiskar ,
I'm using your code and it works fine but the attachment can only be seen from Notes or Activity Log and not from "Manage Attachments". If I manually upload an attachment directly in the destination record form, it appears normally.
Do you know how to solve this issue?
Thanks!
