How to display "When an incident has a knowledge article attached the Knowledge articles "Incident" tab should reflect/populate the incident # that was attached to said article.
06-30-2020 02:48 AM
07-01-2020 12:21 AM
Similarly we have to add incident tab on Knowledge Article form.
Whenever user attach the knowledge article on incident at the same time on knowledge Article form incident should get updated in the related link tab.
07-01-2020 12:24 AM
Okay so which field on knowlege record stores incident number? can you check that
07-01-2020 12:37 AM
Actually i don't see any field where it is storing incident number.
I have used "Attach Knowledge" gear box to see the values stored in fields.
Do i need to check in any other way?
07-01-2020 01:52 AM
there is source field on knowledge table which stores the incident number once knowledge is created from incident
So you can use this for creating relationship
Steps:
1) type relationships in left nav and click on the module under System Definition
2) create new record
3) Applies to Table: kb_knowledge
4) Applies from Table: incident
5) Script below
(function refineQuery(current, parent) {
// Add your code here, such as current.addQuery(field, value);
current.addQuery('sys_id', parent.source);
})(current, parent);
Then add this related list on form by configuring related lists; search and move it from left to right
Output:
07-01-2020 05:19 AM
