How to enable personalize list columns access for users with snc_read_only role
Rajak Shaik
As an snc_read_only user, I would like to personalize the column list on any list screen. Can you please suggest on how it can be achieved.
michaeljacobsz
I recommend the following:
  1. As mentioned above, add the snc_read_only to the glide.ui.personalize_form.role property
  2. Add the 'sys_ui_list' & 'sys_ui_list_element' to the following properties used to be able to store and change the new list sections and list section elements:
    1. glide.security.snc_read_only_role.tables.exempt_write
    2. glide.security.snc_read_only_role.tables.exempt_delete
    3. glide.security.snc_read_only_role.tables.exempt_create
As a result users with the snc_read_only role can use the persenolize list button without the need of any ACL creation.
