How to get current catalog item into reference qualifier ?
Yugi
Hi all,
Is there a way to get a current catalog item into reference qualifier of variable ? I tried current.sys_id, current.sc_cat_item.sys_id, g_form.getParameter("sys_id") but got no luck.
Alberto Consonn
You have to create a variable like "v_cat_id" and populate its values using onLoad catalog client script:
g_form.setValue("v_cat_id", g_form.getParameter("sys_id"));
Once done, use this variable for reference qualifer.
new SIName().functionName(current.variables.v_cat_id);
Hope this will fit your need!
If I have answered your question, please mark my response as correct so that others with the same question in the future can find it quickly and that it gets removed from the Unanswered list.
Thank you
Cheers
Alberto
dvp
can you try
current.cat_item
dvp is spot on.
Great help! worked exactly as needed
Barb5
Mega Contributor
looking for a simple but dynamic reference qualifier on a variable set used to cascade variables into order guide component catalog items,
attribute:
ref_qual_elements=u_catalog_item,is_searchable_choice
where u_catalog_item is a field being used to filter the table return of a Lookup Select box, 2nd attribute is to make Lookup Select Box searchable
reference qualifier:
javascript:'u_active=true^u_catalog_itemCONTAINS' + current.cat_item;
