how to give access only for Incident module
sry
Giga Guru
                      How can i give a user access to only Incidents(Create,Read,Update) and no permissions for Changes,Problems. and also he should not delete any incidents.
I have tried by creating a new role and a new ACL "Incident* write" but its not giving the permissions for all the fields, still the user is able to see only few fields9assignment_group,summary,description). How to create ACL's to give access only to Incidents instead of giving ITIL role.
Sry
"I   have only one issue, when the user "create new" incident he is not able to view all the fields on incident table".-- If   ACL set correctly and updated the incident query BR..next may be to check is the view . Please check the view.[self service view.. Default ] etc.
12 REPLIES 12
thank you pradeep, both you and reghuram solutions will make a complete solution.
Arun81
Couldn't achieve this use-case. I did the following things.
Created a new role custom vendor_itil
Created new ACL's read/write/create on Incident table with "None" for the vendor_itil
Modified the copy of OOB business Incident Query and Incident Functions BR to accommodate the new custom role vendor_itil
But the (vendor_itil) full-fillers are locked down on the editing see below.
Hi Jedi,
I don't know if you already found the cause, but I had the same issue. I and found out that because the grayed out fields are referenced to the task table you also need to add the "task table (read/write/etc.) access control" rights to your new role (vendor_itil).
Best Regards,
Radu
