How to give relationship between incidents and problem table ?
venkataci
hello everyone,Need your suggestions very badly.
I have to relate incident and problem like,in the problem form i have to get incidents in the related lists and vice versa.
I am creating an application in the studio. i have created the respective tables. After giving  the relationship,i am getting all the incidents present in the incident form. How to get rid to this.
please help me out.
I am providing the screenshots for reference.find_real_file.pngfind_real_file.pngfind_real_file.png
HI,
Check Display value of which field is set to true on Problem table.
It should be number but in your case i think it is Assigned to.
Ashutosh munot
brianlan25
Incidents and problem are already related out of the box.  On the incident form you can right click and add the related list Problem->parent and on the problem form you can add the related list Incident->Problem
Thanks for your response.
well, You didn't get my question.when we create a problem in the related lists we should generally have problem=the No. of that problem(near personalize the filter ).Instead of that i am  getting incidents which i marked with red in the photo that i have provided.unable to understand where i went wrong .please help me out
This is because you are using a related list which shows incident as parent.
You might be using a related list called as Incident > Parent
Ashutosh Munot
And if you are using this related list on problem then you have to use Problem as Parent instead of Incident related list.
Please give us a Screen shot of related list. Right click on Header > Configure > Related List and see .
Ashutosh Munot
