How to hide Display filter after clicking edit button in related list
Arkesh Kumar
I am looking to hide Display filter. any help?
Thank you,
Arkesh
Ankur Bawiskar
UI Action based approach based on problem table which is related list on Incident table
1) Visit this OOB UI Action -> Edit on Global Table
URL: https://instanceName.service-now.com/nav_to.do?uri=sys_ui_action.do?sys_id=7fff4c3d0a0a0b3400ad3f1a1d613f74
Update as this so that you create new button for your related list table
a) Action name - sysverb_edit_o2m_problem
b) Condition: (new GlideRecord(current.getTableName())).canWrite() && RP.isOneToMany() && !RP.getListControl().isOmitEditButton() && current.getTableName() == 'problem'
c) Script:
var uri = action.getGlideURI();
var path = uri.getFileFromPath();
uri.set('sysparm_m2m_ref', current.getTableName());
uri.set('sysparm_collection_related_file', current.getTableName());
uri.set('sysparm_form_type', 'o2m');
uri.set('sysparm_stack', 'no');
uri.set('sysparm_query', '');
uri.set('jvar_no_filter', 'true'); // added new
action.setRedirectURL(uri.toString('sys_m2m_template.do'));
d) Do Insert and Stay
2) Now Visit the Edit button which is OOB and update the condition as this so that the OOB button is not visible for your table
Condition: (new GlideRecord(current.getTableName())).canWrite() && RP.isOneToMany() && !RP.getListControl().isOmitEditButton() && current.getTableName() != 'problem'
OOB UI Action After changes
New Edit button
Output:
19 REPLIES 19
so are you saying this
1) users with role A should not be able to change the filter
2) All users without role A should be able to change the filter
Can you explain this?
Filter should be hide for all users except admin user. and list collector should display only active records to all users
Thank you,
Arkesh
You can show active records by giving the query
uri.set('sysparm_query', 'active=true');
Now coming to hiding/showing the filter you can use either of these 2 approaches
1) Create 2 Edit buttons
a) For admin user which won't have this -> uri.set('jvar_no_filter', 'true');
b) for non-admin user which has this -> uri.set('jvar_no_filter', 'true');
OR
2) UI Script I shared can be using to determine the role and hide the filters using DOM
Hi I have updated my script as below and its working fine.
if(gs.hasRole('admin'))
uri.set('jvar_no_filter', 'false');
else
Nice.
I missed that part.
Glad to help.
