How to insert Hyperlink into Resolution notes under Incident Form
MB Ng
Hi, knowing that Additional comments & Worknotes are support HTML to insert Hyperlink but how about Resolution Notes/Closed notes add hyperlink, possible? and How?
see i tried this way, will it work for you ?
Quick Demo
11 REPLIES 11
hvrdhn88
Giga Patron
Let me know if you need any further help,
If your query has solved and my response has helped you, kindly mark it as correct and close this thread.
flawed_81
Would it be safe to change the close_notes type to "HTML" in the dictionary? That would allow format editing and adding links
