How to insert hyperlinks, HTML code, etc. via Flow Designer?
davida1
Giga Expert
I'm trying to create a function via Flow Designer such that an incident is generated when something (a group, in this case) expires. Our homegrown group maintenance system expires things after a year, and in spite of numerous (9) notices, group owners/managers still let their groups expire. To mitigate this, we decided to load the expiration date into the Groups table, and have a flow trigger when that date passes. It generates an incident assigned to the expired group, with information on what to do whether they wish to keep it (likely) or not.
I ran into a snag when I tried inserting into the 'Additional comments' field a hyperlink to the knowledge base article on using the homegrown system. No matter how I enter the URL code, it's partially erased either when I hit 'Enter' or when I click 'Save' on the flow. A URL that looks like:
<a href="https://umd.service-now.com/itsc?id=kb_article&article=KB0011206">
turns into this:
I've tried following tips from "Formatting within Journal fields using HTML & [code]" (https://community.servicenow.com/community?id=community_blog&sys_id=4d9ceae1dbd0dbc01dcaf3231f9619e1). I've got an open incident with HI, but other than direct me to the page above they're still looking into it.
I can put hyperlinks into 'Additional comments' directly, but not via Flow Designer. Anyone had any better luck?
David A
davida@umd.edu
16 REPLIES 16
Ankush Jangle1
Hi Davida,
First Way :-
    In Utilities-->you will get The Option Email
   In Email Body Part you can write the Hyper link code
 <a href="www.gmail.com">Test Link</a>
Second Way:-
you have available option in Email Insert/edit Link
In Url You can Pass the URL
In Text To Display Pass  the name of Url
Please Mark It as Helpful
ANkush Jangale
itpro72
I stumbled upon a solution I thought I'd share specifically if you're looking to link to a table record. This won't work for other types of hyperlinks. There is an action under Alert Management Content to generate a hyperlink to a table record.
That brings you to the form that allows you to set the table, record and name from data in the workflow.
Now you can reference the hyperlink just as you would any other data in your workflow.
In this case you wanted to insert it into additional comments and it worked flawlessly for me.
Hope you find this helpful.
It does work, but unfortunately wraps [code][/code] around the link and the tags are visible in an email body 😕
sg28
I have the same requirement. but I am not getting the "alert management content"  so not getting "generate link to table record" action. Can you please help.
itpro72
I noted after I posted that Alert Management Content is available only with a subscription application. I meant to go back and publish an article with a solution and you have prompted me to do so. Hyperlinks in flow designer contains instruction for a custom action that borrowed from (and improved upon) the action I mentioned above.
