how to JOIN 2 TABLES in SERVICENOW to display different Column data
How to JOIN 2 TABLES in SERVICENOW to display different Column data
- I want so see INCIDENT and SURVEY result in ONE LIST   . plz help
randrews
you will need to create a database View to do the join
http://wiki.servicenow.com/index.php?title=Database_Views
that is the wiki on it.. the easiest way to learn them is to look at the wiki then examine a few in your sub prod instance.. from there play with it.
Renuka8
You can also refer to some previous threads on Database Views which is very helpful
Database Views
Re: database view for specific reporting
Thanks, to all for clearing up on database view
if you have any more specific answers please ask away.. if one of us helped you or resolved the question please mark their answer as helpful and if this is answered please mark it as answered.. helps when going through articles if the ones answered are marked answered.
