How to Map a Variable from Record Producer to a field on Incident form?
User177031
HI All,
I am having a variable as 'Users Affected' (Values - Widespread, Large, Limited, Localized) on Record Producer and I want to map this to 'Impact' field on Incident form.
Widespread - Critical
Large - High
Limited - Medium
Localized - Low
Example - When User submit an Incident through record producer with Users Affected as 'Large', it should show as 'High' Impact on the Incident form.
Please help me to achieve this requirement.
- Thank you.
senthilvaithees
Write a script like this if(producer.user_affected=='large') current.impact ='high';
Hi Senthil,
Where do I need to write? and what type of script is this (Client Script/UI Policy)?
- Thank you.
Hi Sai,
Write the script in the script area present under 'what it will contain'. This area is used to transfer the values of the field from record producer to incident record field.
Refer this Link for further understanding
Ankittanwar
Mega Contributor
Hi paul ,
Can you please help me for the same on Impact , urgency , priority Field on incident form .
we want to map Variable value(Record producer )   into field ( Incident form ) .
