‎01-12-2022 12:54 AM
We have a requirement. If a user selects an Application from 'app_service' then tags related to that application will populate in a different field. So, if an application has 3 tags, how to populate those 3 tags? If an application has 1 tag, it is populating fine but problem is with more than 1 tag.
Catalog Client Script:
var a = g_form.getValue('app_service');
alert(a);
var ga = new GlideAjax("TagPop");
ga.addParam("sysparm_name", "getTagName");
ga.addParam("sysparm_groupid", a);
ga.getXML(setTagName);
function setTagName(response) {
g_form.clearValue('subscription_name');
g_form.clearOptions('subscription_name');
alert(answer);
g_form.setValue('subscription_name', answer);
Script Include:
var TagPop = Class.create();
TagPop.prototype = Object.extendsObject(AbstractAjaxProcessor, {
getTagName: function() {
var efg = '';
var nam = this.getParameter('sysparm_groupid');
//gs.log('h1' + nam);
//var t = nam.getDisplayValue();
//gs.log('h2' + t);
var abc = new GlideRecord('label_entry');
abc.addQuery('title', 'CONTAINS', nam);
//var vendors = [];
abc.query();
if (abc.next()) {
efg = abc.label.getDisplayValue();
//vendors.push(efg.getUniqueValue());
return efg;
//return 'sys_idIN'+vendors.toString();
type: 'TagPop'
Please help!
‎01-12-2022 02:28 AM
Updated CLient Script code to be used here as below:
if (newValue) {
var ga = new GlideAjax('getTags');
ga.addParam('sysparm_name', 'getTagsValue');
ga.addParam('sysparm_val', newValue);
ga.getXML(getTags);
function getTags(response) {
alert(answer);
var splitAnswer = answer.split(',');
for(var i=0;i<splitAnswer.length;i++){
g_form.setValue('description',g_form.getValue('description') + '\n' + splitAnswer[i]);
This will ensure that tags appear in different lines as you said, did not read it initially but have modified it. Let me know for an issue here.
Shloke
‎01-12-2022 03:21 AM
Thanks for confirming that my script worked.
to show them in new line just do this
var vendors = [];
abc.query();
while(abc.next()) {
vendors.push(abc.label.getDisplayValue());
return vendors.join('\n');
type: 'TagPop'
Did you mistakenly marked other response as correct?
I believe I answered your question and mentioned to use string or multi-line text variable.
There can be only 1 response marked as correct.
Kindly mark the answer correct based on response given quickly and accurately.
‎01-12-2022 01:26 AM
Try:
var efg = [];
abc.query();
if (abc.next()) {
efg = push(abc.label.getDisplayValue());
return JSON.stringify(efg)
type: 'TagPop'
Then on Client side you can use:
answer = answer.split(',');
EXAMPLE:
*** Script: ["a","b"]
‎01-12-2022 01:40 AM
Hi Patryk,
I tried this but its not working. Showing error of Javacript error in browser console.
Thanks!
‎01-12-2022 01:47 AM
there was space before dot.
try now
‎01-12-2022 01:43 AM
Can you send me an error?
