How to populate a Reference field automatically (no dot-walking, GlideAjax)
Alberto Consonn
Hi guys,
I need an help for configuring the Advanced Reference Qualifier in the right way.
In the Time Worker table, I've created a Reference custom field "Account_ref" to the customer_account table.
I would like to fill this field automatically with the account of the selected task, I tried dding with the following Advanced Reference Qualifier...no luck.
javascript:'account='+current.task;
Thanks for your help!!!
Dubz
Hi Alberto,
I replicated your config and figured out the issue, real rookie error for which i accept full responsibility 🙂
The function call in the getXMLAnswer() line is in quotes, it shouldn't be! use this:
//client script
	var ga = new GlideAjax('TestScriptInclude');
	ga.addParam('sysparm_name', 'testFunction');
	ga.addParam('sysparm_task', g_form.getValue('task'));
	ga.getXMLAnswer(getAjaxData);
	function getAjaxData(response){
		g_form.setValue('u_account_ref', response);
EDIT: Just noticed Harsh has already picked this up!
36 REPLIES 36
Alberto Consonn
Hi David,
I tried to use the following onChange client script but it's raising the error below:
   var task = g_form.getValue('task');
	g_form.setValue('u_account_ref', task.account.name);
Any idea?
Thanks a lot
dot walk will not work here, until you use callback function in your client script. A
The Fantastic g_form getReference Callback
try using callback function
I tried but still getting "undefined" with the below code, could you please help me?
   var task = g_form.getReference('task', setAccount);
function setAccount(task) {
    if (task)
        g_form.setValue('u_account_ref', task.account);
can you give a try again
g_form.getReference('task', cbFunc);
function cbFunc(gr) {
    var test= gr.getValue('account');
    alert('Value is ' +test);
i tested this way and its working for me.
