How to populate a Reference field automatically (no dot-walking, GlideAjax)
Alberto Consonn
Hi guys,
I need an help for configuring the Advanced Reference Qualifier in the right way.
In the Time Worker table, I've created a Reference custom field "Account_ref" to the customer_account table.
I would like to fill this field automatically with the account of the selected task, I tried dding with the following Advanced Reference Qualifier...no luck.
javascript:'account='+current.task;
Thanks for your help!!!
Dubz
Hi Alberto,
I replicated your config and figured out the issue, real rookie error for which i accept full responsibility 🙂
The function call in the getXMLAnswer() line is in quotes, it shouldn't be! use this:
//client script
	var ga = new GlideAjax('TestScriptInclude');
	ga.addParam('sysparm_name', 'testFunction');
	ga.addParam('sysparm_task', g_form.getValue('task'));
	ga.getXMLAnswer(getAjaxData);
	function getAjaxData(response){
		g_form.setValue('u_account_ref', response);
EDIT: Just noticed Harsh has already picked this up!
36 REPLIES 36
Alberto Consonn
You're right, sorry my bad. It's still not working, I was not able to read in the Case table (see error message below)...I've created a new Application Cross-Scope Access privilege into the Time Recording for Customer Service application...now I don't get any error but still do not populate the Account_ref field, it's doing nothing 😞
If you go to the table and change it to allow access to all application scopes that should open it up.
Alberto Consonn
I think this client script is doing nothing, I don't see any error or information in the logs but still the account_ref field is not getting populated even if I try to change the Task...
is it possible if you can share the complete code which you have written ?
are you in scoped application ?
I've changed everything to Global application (Script Include and Client Script), these are the actual code:
CLIENT SCRIPT (Table: Time Worked [task_time_worked], Type: onChange, Field name: Task, Application: Global):
	var ga = new GlideAjax('test');
	ga.addParam('sysparm_name', 'test_function');
	ga.getXMLAnswer('getAjaxData');
SCRIPT INCLUDE (Name: test, Application: Global, Client callable: checked):
var test = Class.create();
test.prototype = Object.extendsObject(global.AbstractAjaxProcessor, {
test_function: function(){
var tsk = this.getParameter('sysparm_task');
var gr = new GlideRecord('sn_customerservice_case');
if(gr.get(tsk)){
return gr.getDisplayValue('account');
type: 'test'
