How to populate a Reference field automatically (no dot-walking, GlideAjax)
Alberto Consonn
Hi guys,
I need an help for configuring the Advanced Reference Qualifier in the right way.
In the Time Worker table, I've created a Reference custom field "Account_ref" to the customer_account table.
I would like to fill this field automatically with the account of the selected task, I tried dding with the following Advanced Reference Qualifier...no luck.
javascript:'account='+current.task;
Thanks for your help!!!
Dubz
Hi Alberto,
I replicated your config and figured out the issue, real rookie error for which i accept full responsibility 🙂
The function call in the getXMLAnswer() line is in quotes, it shouldn't be! use this:
//client script
	var ga = new GlideAjax('TestScriptInclude');
	ga.addParam('sysparm_name', 'testFunction');
	ga.addParam('sysparm_task', g_form.getValue('task'));
	ga.getXMLAnswer(getAjaxData);
	function getAjaxData(response){
		g_form.setValue('u_account_ref', response);
EDIT: Just noticed Harsh has already picked this up!
36 REPLIES 36
	var ga = new GlideAjax('test');
	ga.addParam('sysparm_name', 'test_function');
	ga.getXML('getAjaxData');
function getAjaxData(response) {
  alert(answer);
var test = Class.create();
test.prototype = Object.extendsObject(global.AbstractAjaxProcessor, {
test_function: function(){
var tsk = this.getParameter('sysparm_task');
gs.log('what is the value for task'+tsk);
var gr = new GlideRecord('sn_customerservice_case');
if(gr.get(tsk)){
gs.log('Value is'+gr.getDisplayValue('account'));
return gr.getDisplayValue('account');
type: 'test'
can you try now and let us know what are you getting in logs and alert
I didn't get any alert in the form...this is the log Information:
do one thing, store gr.getDisplayValue('account'); in one variable and then return it.
also pass the normal alert inside the ajax function in client script
var res;
if(gr.get(tsk)){
res=gr.getDisplayValue('account');
gs.log(' function returning '+ res);
return res;
type: 'test'
ga.getXML(getAjaxData);
alert(answer);
i got it .. we were passing the single quote.
