‎10-05-2021 06:35 AM
I have issue where there are two drop downs in Incident form.
Product Line - this is populating from choices we have added to sys_choice table
Based on the selected product line value related Products have to populate into the Products drop down.
I'm populating these products value from Choice mapping custom table.
In Incident.
Product Line-String
Product column - String
See below screenshots.
I have written a Onchange Client script as below but can't populate 'Product' drop down.
Can anyone please give some guidance on this how to achieve this.
var prod_line = g_form.getValue('u_p_line');
var gr=new GlideRecord('u_choice_mapping');
gr.addQuery('u_product_line',prod_line);
while(gr.next())
g_form.setValue('u_product',gr.u_product_choice_mapping);
‎10-05-2021 10:18 AM
Use the same code in OnChange script
Sample code:
g_form.clearOptions('u_integer_f');
//your code here
var ga = new GlideAjax('HelloWorld');
ga.addParam('sysparm_name', 'helloWorld');
ga.addParam('sysparm_user_name', newValue);
ga.getXML(HelloWorldParse);
function HelloWorldParse(response) {
// alert(answer);
var x = answer.split(",");
for (var i = 0; i < x.length; i++)
g_form.addOption('u_integer_f', x[i], x[i]);
Mark it helpful if this helps you to understand. Accept solution if this give you the answer you're looking for
Kind Regards,
Rohila V
5x ServiceNow MVP
Sample code:
//your code here
// alert(answer);
Kind Regards,
Rohila V
5x ServiceNow MVP
‎10-05-2021 09:26 AM
Is there a reason why you are not simply using the sys_choice table to contain the list of products? Would simplify things.
‎10-05-2021 09:45 AM
Since the number of choices are too high in the sys_choice. We want to keep some into separate table, which there can be more choices added in the future
