how to populate the catalog variable values to RITM description
Pushpa
Mega Expert
Hi Team,
how to populate the current catalog variable values  to RITM description
below variables and variable set fields.
i have 3 variables and one variable set (variable set have 2 fields).
variables
1. account
2. year
3.quarter
variable set
4. select location  (location and balance)
how write workflow run script
@Ankur Bawiskar
Pushpa
account variable should work fine using this
current.variables.account.getDisplayValue();
OR you can query the account table with the sys_id and print the name
then for stockroom showing country do this
var desc = current.variables.description;
if (current.cat_item.name == "Laptop Projection Request") {
    desc += '\nAccount: ' + current.variables.account.getDisplayValue();
    desc += '\nYear: ' + current.variables.year;
    desc += '\nQuarter: ' + current.variables.quarter;
    var parser = JSON.parse(current.variables.add_stockroom_location_and_projection);
    var arr = [];
    for(var i=0;i<parser.length;i++){
        var gr = new GlideRecord("alm_stockroom"); // give here the table name
        gr.addQuery("sys_id", parser[i].stockroom);
        if (gr.next()) {
            var str = '';
            str = str + "Stockroom: " + gr.location.country + " | " + gr.name + " Projection: " + parser[i].projection;
            arr.push(str);
    desc += '\nAdd Stockroom Location and Projection: ' + arr.join('\n');
    current.description = desc;
    current.update();
25 REPLIES 25
so how are you creating the catalog task?
is it via workflow catalog task activity then do similar script in the advanced script section
use this script in the script advanced section
    var arr = [];
        if (gr.next()) {
            var str = '';
            arr.push(str);
    task.description = desc;
