How to pull "Requested Item Summary" field values of sysapproval_approver to notification body?
sharsha
How to pull all related field values of "Requested Item Summary"  of a sysapproval_approver record to a notification body using Email template in Servicenow?
Please see attached and advise if you've any idea!?
3 ACCEPTED SOLUTIONS
vaishali231
Hey @sharsha
Try this :
Step 1: Create a Notification Email Script
Create a new Email Script (for example, RITM_Variable_Summary)
code:
(function runMailScript(current, template, email, email_action, event) {
var ritm = current.sysapproval.getRefRecord();
if (!ritm || !ritm.isValidRecord())
template.print("<h3>Requested Item Summary</h3>");
template.print("<table border='1' cellpadding='5' cellspacing='0' style='border-collapse:collapse;width:100%;'>");
template.print("<tr style='background:#f2f2f2;'>");
template.print("<th align='left'>Question</th>");
template.print("<th align='left'>Response</th>");
template.print("</tr>");
var variables = ritm.variables.getElements();
for (var i = 0; i < variables.length; i++) {
var variable = variables[i];
template.print("<tr>");
template.print("<td>" + variable.getQuestion().getLabel() + "</td>");
template.print("<td>" + variable.getDisplayValue() + "</td>");
template.print("</table>");
})(current, template, email, email_action, event);
Step 2: Call the Mail Script in the Notification
In your Approval Notification (Table: sysapproval_approver), add the following to the Message HTML:
${mail_script:RITM_Variable_Summary}
If this response helps, please mark it as Accept as Solution and Helpful.
Doing so helps others in the community and encourages me to keep contributing.
Vaishali Singh
Servicenow Developer
Linkedin - https://www.linkedin.com/in/vaishali-singh-2273361bb
Ankur Bawiskar
@sharsha
You need to use email script in your email body and include it in email
Mail script: print_cat_item_request_submitted
Script
// Add your code here
template.print('Requested Item Summary: <br/>');
var ritm = new GlideRecord('sc_req_item');
ritm.get('request', current.sysapproval);
for (var i=0;i<variables.length;i++) {
var question = variables[i].getQuestion();
var label = question.getLabel();
var value = question.getDisplayValue();
if(label != '' && value !=''){
template.space(4);
template.print(' ' + label + " = " + value + "<br/>");
Tanushree Maiti
Hi @sharsha
To retrieve the fields and variables of a Requested Item (RITM) from a sysapproval_approver record in an email notification, use an Email Script.
Note: Standard dot-walking (for example, ${sysapproval.variable_name}) does not reliably display catalog variables, especially multi-line variables or complete variable summaries.
Refer: https://www.servicenow.com/community/itsm-forum/requested-item-variables-in-email-body-for-approval/...
https://www.servicenow.com/community/developer-forum/email-template-for-approval-grab-variable-for-e...
You can try this sample email script.
1: Create an Email Script
Navigate to System Policy > Email > Notification Email Scripts and create a new script.
  • Name: ritm_summary_details
    var ritmSysId = current.getValue('sysapproval');
    if (ritmSysId) {
        var ritmGR = new GlideRecord('sc_req_item');
        if (ritmGR.get(ritmSysId)) {
            template.print('<h3>Requested Item Summary</h3>');
            template.print('<b>Item:</b> ' + ritmGR.cat_item.getDisplayValue() + '<br />');
            template.print('<b>Item Number:</b> ' + ritmGR.getValue('number') + '<br />');
            template.print('<b>Quantity:</b> ' + ritmGR.getValue('quantity') + '<br />');
            template.print('<b>Short Description:</b> ' + ritmGR.getValue('short_description') + '<br /><br />');
             template.print('<b>Options / Variables Selected:</b><br />');
            var variables = ritmGR.variables;
            for (var keyRitm in variables) {
                var varRitm = variables[keyRitm];
                  if (varRitm.getGlideObject().getQuestion().getLabel() != '' && varRitm.getDisplayValue() != '') {
                    template.print('&nbsp;&nbsp;&bull;&nbsp;' + varRitm.getGlideObject().getQuestion().getLabel() + ': ' + varRitm.getDisplayValue() + '<br />');
2: Call the Script in Your Email Body/Template
  • Open the targeted Email Template or Notification record configured on the sysapproval_approver table.
  • Insert the script call inside the Message HTML body
Dear ${approver},
An approval request has been generated for your review.
${mail_script:ritm_summary_details}
Click here to view the approval: ${URI_REF}
Tanushree Maiti
9 REPLIES 9
vaishali231
Hey @sharsha
Try this :
code:
Vaishali Singh
Hey @sharsha
Hope you are doing well.
Did my previous reply answer your question?
If it was helpful, please mark it as correct ✓ and close the thread . This will help other readers find the solution more easily.
Thankyou & Regards
Vaishali Singh
Ankur Bawiskar
@sharsha
Script
template.space(4);
@sharsha
Just following up to see whether my suggested solution worked for you.
If you're still facing any issues, I'd be happy to help further.
Tanushree Maiti
Hi @sharsha
    if (ritmSysId) {
Dear ${approver},
Tanushree Maiti
