How to reset Incident "Default View" for 1 User
Michael Wellnha
Giga Contributor
Hi all,
one of our Users encountered a little problem that I can´t seem to fix.
Since he logged in today his standard view for all Incident Modules is "Incident Manager".
He cannot select "Default View".
Where can I find the problem?
Thanks in advance for every helpful reply.
Michael
Tried this in my personal instance, it works fine:
  • open the user preference table and search by the name of the preferences with the table name of the list view
  • delete the user preference for that specific user
16 REPLIES 16
could you clear cache and then ask the user to logout and login once and check.
All of my view are currently set to Default with the exception o RITM.
When my user had this problem I made the same change on my (admin) profile and I cannot change it back to Default either.
