How to reset 'Remember my decision' when exporting to Excel
georgechen
Hi folks,
Can anyone please help the confirmation dialog in exporting reports in ServiceNow on the bulk data exporting to Excel.       I have a client who ticked 'Remember my decision' by 'Mail it' so each time it he has to wait for the email.
Is there a way this settings can be reset?
any advice would appreciated.
michalk
Giga Contributor
I had the same problem.
Clearing History didn't help.
U need to go to - User Preferences - export_warn - and delete "email" in Value field.
This worked for me.
12 REPLIES 12
michalk
Giga Contributor
This worked for me.
vinothkumar
Hi George,
If you tick the checkbox and click Mail It, your decision will be saved as a preference in a User Preferences [sys_user_preference] table:
Value: email
User: you
If you manually delete this preference, the system will ask you the same question the next time you try to export a large data set and this will help to fix this issue.
Sherin3
We don't have the export_warn property in Jakarta. how can this be fixed in Jakarta, kindly assist.
Deepchand_Yadav
Then You need to close your browser and open again.
This worked for me .
Ed Shooshanian1
Kilo Expert
Can anyone from ServiceNow jump in and provide a solution which can be adjusted by the end-user.  Seems odd to have an end-user setting which requires an admin to correct and deleting a record seems like a really bad design.
Or am I missing an option for an end-user?  But I can't get to user preferences on the menu and I don't see an option in my profile.
