How to set a catalog item variable to ReadOnly?
gourav2
Kilo Expert
There is one Catalog Item and when I select a particular field or variable then some   another variable should become ReadOnly or I can set some values in it. Which one will be the best way, an onChange Client Script or UI Policy?
Hi Gourav,
addOption() needs atleast three parameters-
1st - field name
2nd - Choice Value to be added
3rd - Choice Label of the choice value to be added
4th(optional) - index of the choice to be added in the drop down
You are missing labels of the added choices so you were not getting any names for the added options and were shown blank.
Try this code-
    if(newValue == 'XYZ')
      g_form.setReadOnly('url', true);
      g_form.setValue('url', 'N/A');
      g_form.setValue('trans_sb_Environment', 'Production');
      g_form.setReadOnly('Environment', true);                   //If you are setting it to read only then why are you removing options from it
      g_form.removeOption('Environment', 'Dev');         // You just need to set this field to required option. This and next line is not required
      g_form.removeOption('Environment', 'Stage');         //As its read only user will not be able to select any other value
      g_form.removeOption('TypeIssue', 'Administration Module');
      g_form.addOption('TypeIssue', 'Access Request','Access Request');                 //If you want to remove all options use clearOptions() instead
      //g_form.setDisplay('Access Request', true);                   You don't need this line as it will always be displayed until you remove it
      g_form.addOption('TypeIssue', 'Request','Request');
      //g_form.setDisplay(' Request', true);         You don't need this line as it will always be displayed until you remove it
  else
        g_form.setReadOnly('url', false);
        g_form.setValue('url', '');
        g_form.setReadOnly('Environment', false);
  g_form.addOption('Environment', 'Dev','Dev');
//   g_form.setDisplay('Dev', true);         You don't need this line as it will always be displayed until you remove it
    g_form.addOption('Environment', 'Stage','Stage');
// g_form.setDisplay('Stage', true);         You don't need this line as it will always be displayed until you remove it
I have also mentioned few suggestions in the comments. Please apply which are applicable to you.
For more help check below links-
GlideForm (g form) - ServiceNow Wiki
Removing or Disabling Choice List Options - ServiceNow Guru
Tanaji Patil
--Mark correct/helpful if it helps solving your issue.
Shouldn't you be displaying the TypeIssue field, and not the options you've added?
      g_form.addOption('TypeIssue', 'Access Request');
      g_form.setDisplay('Access Request', true);         <-------------------------
      g_form.addOption('TypeIssue', 'Request');
      g_form.setDisplay(' Request', true);       <-------------------------
  else
  g_form.addOption('Environment', 'Dev');
g_form.setDisplay('Dev', true);                   <--------------------
    g_form.addOption('Environment', 'Stage');
  g_form.setDisplay('Stage', true);                   <--------------------
Hi Gourav,
1st - field name
Try this code-
  else
Tanaji Patil
And also for your information-
Usually UI policies works onChange as soon as the conditions are met.
Also they can be made to run onLoad by checking onLoad check box in advance view.(by default its checked).
You can use both,UI policy or Client script, to achieve your requirement.
I always prefer UI policies (instead of onChange or onLoad client scripts) because-
1. its easier to configure as it has condition builder and policy actions (with no script required).
2. You can set order in UI policies.
3. You can also write script in advanced view.
4. Unlike client scripts code runs only when relative conditions are met.
There is only one thing we have to keep in mind with UI policies is that UI policy will not run agian if you already have met the condition.
For example,       for condition1 you want action1
                                                for condition2 you want action2
If you check both these, condition1 and condition2 in a UI policy and try to run respective actions, action1 and action2, in the script after checking the condition met in the script this will not give you full result.
Suppose condition1 is satisfied. This will run action1. But now if condition2 is met immediately then the UI policy will not run again as its already met and action2 will not be applied.
But you can write 2 separate UI policies for both the conditions. Problem is when the number of such conditions(with different action for each condition) are more. You need one UI policy for each such condition.
Working perfectly fine guys, thank you very much.
