How to set incident state is "WIP" automatically
11-15-2022 05:44 AM
Hello expets
We have requirment.
We have a field is Due date. If below conditions are met field will be visible. or else Hide.
Requirement is
Incident should switch back to WIP as soon as the set date/time is reached.
Please support to achieve this
Incident Management
11-15-2022 09:39 PM
Glad to help.
11-15-2022 10:10 PM
Thanks for motivating me!
I tried with below code but unfortunately not working properly.
function onLoad() {
var postpone = g_form.getValue('u_postpone_schedule');
var ajax = new GlideAjax('date/timeToday');
ajax.addParam('sysparm_name', 'date/timeToday');
ajax.addParam('sysparm_postpone', postpone);
ajax.getXMLWait();
var answer = ajax.getAnswer();
g_form.setValue('state', 2);
Issue is normally state is in on hold.
But after opening only the incident it is changed to InProgress
But my requirment is if Postpone date is reached then incident should be switch to inprogress automatically.
or else we can achieve this by any Before/after BR?
Plesae help me on this ,
Thank you.
11-15-2022 10:32 PM
you can use Display business rule on incident table and check this
// Add your code here
var nowTime = new GlideDateTime();
var postpone = new GlideDateTime(current.u_postpone_schedule);
if(nowTime.getNumericValue() == postpone.getNumericValue())
g_scratchpad.isDateReached = 'true';
else
g_scratchpad.isDateReached = 'false';
})(current, previous);
onLoad client script
function onLoad(){
if(g_scratchpad.isDateReached == 'true')
11-15-2022 11:06 PM
Thank you for your Quick reply ,
i tried above code but unfortunately not working. Please correct me if any wrong.
11-15-2022 11:10 PM
what's your current time and what's the time in that field?
date is same but time should also be same -> but it would be very difficult since time has seconds also in it
try this
var postpone = new GlideDateTime();
postpone.setDisplayValue(current.u_postpone_schedule):
else
