How to set state value using Flow Design ?
karishma shaik
Hi Team,
My Requirement is in custom table How to set state value using Flow Design .
in work flow we are using set values moving next state , in flow design is there any option?
karishma.
Ankur Bawiskar
In the flow you can use Update Record action and use Field Values to set the value for field for the record
Can you share your flow screenshot
Chandu Telu
Using Update record Action You can achieve this
https://docs.servicenow.com/bundle/quebec-servicenow-platform/page/administer/flow-designer/reference/update-record-flow-designer.html
Chandu Telu
Please Mark Correct/helpful, if applicable,
Ankur Bawiskar
