05-07-2026 02:17 AM
Hello Everyone,
I have a flow on incident and it is integrated with a thirdparty tool and its aoutbound.
I have created one custom action used and everything is fine i am able to create the incident in the thirdparty system.
Now we have a requirement like if the integration fails due to any error. It should try the same rest call two more time if still error then it should create one incident .Now please look at the attached scrrenshots and let me know how i can do this?
In my custom action where after rest step whatever response i am getting i am parsing it in the json parser and then getting the values and updating the incident.
the current requirement is about the negative scenarion if integration fails then it should try two more times if still fails then i have to log one incident record with the eroor and the incident details so the admin team can check.
@Ankur Bawiskar how i should be able to achieve this?
05-07-2026 04:06 AM
I haven't tried but it should work based on the links I shared
05-07-2026 02:41 AM
did you try Retry policy?
also check below
Handling ServiceNow flow errors with a flow
05-07-2026 02:53 AM
Hello @Ankur Bawiskar ,
Irrespective of the error i have to try the integration for 3 times so i have created the below policy and using it in the custom action is it correct condition.
05-07-2026 04:06 AM
