How to show only users from respective group in reference field (sys_user) table
Santhosh23
Can anyone please explain me how to filter the users from only one group in reference fields reference to sys_user table.
Ankur Bawiskar
you need to use advanced reference qualifier on that user reference field
javascript: 'sys_idIN' + new GetGroupMembers().getUsers();
Script include
var GetGroupMembers = Class.create();
GetGroupMembers.prototype = {
	initialize: function() {
	getUsers: function(){
		var arr = [];
		var gr = new GlideRecord("sys_user_grmember");
		gr.addQuery("group.name", "ABC Group");
		while(gr.next()) {
			arr.push(gr.getValue('user'));
		return arr.toString();
	type: 'GetGroupMembers'
RudhraKAM
This might be Old post but just adding other option, so that some one can use it ,
In the Reference variable , Select group member table and use the group sysID , this will fix the issue
