How to switch Topics using topicDiscovery()
Vishal Sharma3
I am using switchtopic() to switch topics but When I use this function, Option to start a new conversation is not coming in virtual agent. See below image:
Now, I want to use topicDiscovery() to switch the Topics but I do not know the exact syntax and procedure to use the same. Can anyone please help me that how do we use topicDiscovery() to switch to specific topics?
@Mark Roethof
Basically it's just what's mentioned in this article:
50+ (Un)documented Virtual Agent variables (vaInputs, vaVars, vaContext, vaSystem)
Or just example script:
(function execute() {
    vaVars.global_search_text = 'Topic Name to Switch to';
    vaSystem.topicDiscovery();
Be aware: Name of the topic, not sys_id!
Kind regards,
Mark
2020-2022 ServiceNow Community MVP
2020-2022 ServiceNow Developer MVP
LinkedIn
Community article, blog, video list
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
tarek_elkelani
I believe it is
vaSystem.switchTopic(vaVars._setup_explore_help_topic);​
The OOB behavior of the Anything Else Topic will start a new conversation when you answer "Yes" to the "Is there anything else I can assist you with?"
Thank you
@tarek.elkelani
Hi, I want to know the syntax of topicDiscovery().
Vishal Sharma3
@Mark Roethof Can you please add your input here if anything.
Sure will look into it shortly!
Kind regards,
Mark
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
