How to translate confirm message from client script?
Hi Experts,
We have a requirement to translate a confirm message from client script.
confirm("You confirm that all information being submitted is accurate. If you are unsure select Cancel to return to editing, otherwise select OK.")
I tried below way and its not working
getMessage(("update personal information message", function(msg){
confirm(msg);}
Any one come across this translation? Please suggest.
Antony
Below setup for example, results correctly in Dutch in "Hallo", instead of English "Hello".
Kind regards,
Mark
2020 ServiceNow Community MVP
2020 ServiceNow Developer MVP
LinkedIn
Community article list
11 REPLIES 11
Amongst others I've successfully tested with:
confirm(getMessage('Test'));
So drop the g_form part if you are going for a confirm.
Kind regards,
Mark
LinkedIn
Hi Mark,
No luck with the above line also.
Antony
Can you share your full script and client script settings? I assume you did check that the client script is executed?
Kind regards,
Mark
LinkedIn
Hi Mark,
Below is my client script. When i click on submit first time its showing the message key only. But when i click cancel button and when i again submit the item second time then its showing the Message correctly. Do
you know what might be the cause?
The script is fine. Though... did you use the Message field? Not seeing the field on your form, guess you didn't use it.
If I use the Message field and even literally test your code: works fine.
Kind regards,
Mark
LinkedIn
