how to trigger notification using script include and onchage client script.
mastanbe
Hi all , @Ankur Bawiskar @shloke04 please help me on this
i have a requirement that when user enter email id and moved to next field then i wannt  to trigger a notification to that email.
please help me on this how to write a code.
shloke04
Hi @mastanbe
After going through your comments below, please follow the steps below to achieve your requirement:
1) Create a On Change Catalog Client Script on your Catalog Item or Record Producer on your Email Variable which ever you have created and use the script below:
    if (newValue) {
        var gaEmail = new GlideAjax('triggerNotif');
        gaEmail.addParam('sysparm_name', 'sendNotif');
        gaEmail.addParam('sysparm_email', newValue);
        gaEmail.getXMLAnswer(_handleResponse);
        function _handleResponse(response) {
            var answer = response;
            if (answer == true) {
                g_form.addInfoMessage('Email has been sent to your Email ID');
2) Create a Client Callable Script Include and try the script below:
var triggerNotif = Class.create();
triggerNotif.prototype = Object.extendsObject(AbstractAjaxProcessor, {
	sendNotif : function(){
		var getEmail  = this.getParameter('sysparm_email');
		var gr = new GlideRecord('sys_email');
		gr.initialize();
		gr.user = getEmail;
		gr.type = 'send-ready';
		gr.notification_type = 'SMTP';
		gr.subject = 'Enter the Subject of your Email';
		gr.recipients = getEmail;
		var success = gr.insert();
		if(success){
			return true;
    type: 'triggerNotif'
Please try this in your lower environment first, I have not tested it.
Shloke
mastanbe
Hi @ankur bawiskar
Please help me on this
Tony Chatfield1
Hi, can you explain why you need to trigger a notification before the email address change is saved?
What happens if the user changes their mind and aborts the update(s) that they have made to the record in the UI?
I would not recommend this as best practice,
but if you must deliver this as a solution then you would simply need to use GlideAjax to trigger a sysevent, passing in the email address as an event parameter and then consume it with a notification.
https://developer.servicenow.com/dev.do#!/reference/api/sandiego/client/c_GlideAjaxAPI?navFilter=glideajax
https://developer.servicenow.com/dev.do#!/reference/api/sandiego/server_legacy/c_GlideSystemAPI#r_GS-eventQueue_S_O_S_S_S?navFilter=eventqueue
https://docs.servicenow.com/bundle/sandiego-servicenow-platform/page/administer/notification/task/t_CreateANotification.html
Hi Tony,
i am asking the solution for bank applications for when ever user enter their details like for  mobile number validations i want to send otp for that mobile and also for email validation i want to send a email otp for that email vallidation thatswhy i am asking this
for this i am created a reccord producer for this
I would have thought that this scenario would have required that the data changes were recorded\audited, but if you need to trigger in real time without saving, then an onChange() client script triggering a sysevent via a GlideAjax call would be the method that I would use.
