04-12-2022 11:56 PM
Hi all ,
how to trigger notification using script include and onchage client script.
i have a requirement that when user enter email id and moved to next field then i wannt to trigger a notification to that email.
please help me on this how to write a code.
Cost Management (ITSM)
04-17-2022 12:00 AM
Hi
After going through your comments below, please follow the steps below to achieve your requirement:
1) Create a On Change Catalog Client Script on your Catalog Item or Record Producer on your Email Variable which ever you have created and use the script below:
if (newValue) {
var gaEmail = new GlideAjax('triggerNotif');
gaEmail.addParam('sysparm_name', 'sendNotif');
gaEmail.addParam('sysparm_email', newValue);
gaEmail.getXMLAnswer(_handleResponse);
function _handleResponse(response) {
var answer = response;
if (answer == true) {
g_form.addInfoMessage('Email has been sent to your Email ID');
2) Create a Client Callable Script Include and try the script below:
var triggerNotif = Class.create();
triggerNotif.prototype = Object.extendsObject(AbstractAjaxProcessor, {
sendNotif : function(){
var getEmail = this.getParameter('sysparm_email');
var gr = new GlideRecord('sys_email');
gr.initialize();
gr.user = getEmail;
gr.type = 'send-ready';
gr.notification_type = 'SMTP';
gr.subject = 'Enter the Subject of your Email';
gr.recipients = getEmail;
var success = gr.insert();
if(success){
return true;
type: 'triggerNotif'
Please try this in your lower environment first, I have not tested it.
Shloke
04-13-2022 10:56 PM
HI can you send me the sample code for that how to pass parameters in the script include
and also send me the smaple code for this
04-14-2022 02:38 AM
Steps
- Link the email notification be fired by an event.
- Use GlideAjax from the script include to fire the event.
- That will send the notification.
I hope you are aware on configuring notifications, event and scripting on GlideAjax
04-17-2022 08:05 PM
Hope you are doing good.
If my response helped please close the thread by marking appropriate response as correct so that it benefits future readers.
04-17-2022 12:00 AM
Hi
if (newValue) {
gr.initialize();
gr.user = getEmail;
if(success){
return true;
Shloke
