How to use 'catalog variables' in conditions or adavanced conditions on email notifications
Sarah Bouil
I have written my Notification on sysaproval_approver table. So the catalog variables on RITM table. I am not sure how can I add catalog variables in condition or advanced conditions.
Just assume the catalog variable 'Access' is a Type of Select Box with options prod and non_prod.
So my Notification should be executed if the Access(catalog item variable) is non_prod.
or is it possible by writing script in Advanced condition(under When to send) like below:
var v = current.sysapproval.ref_sc_req_item.variables.access;
answer = v?"true" == v:non_prod;
I tried with above code but the notification is not triggering.
I tried to put some logs:
gs.log(v) is printing- non_admin but when I try to print gs.log(answer)- it's False so that might be the reason.
Kindly help me what was the issue with my script in advanced condition?
15 REPLIES 15
yes @Sarah Bouil
did you try it?
but where are we checking if the type_of_role is non_admin then the notification should trigger?
@Sarah Bouil Does your who will receive section is empty?
Under Who will receive:
Users/Groups: Approver and Groups: SNow Admin
If no Advance condition then Notification is executing and its showing in Email logs
But if I have an Advanced condition, the Notification is not executing.
@Sarah Bouil,
Maybe the problem stands in the catalog items value. Check if the value corresponds to the value in the notification advanced script.
I see no reason why it wouldn't work otherwise.
