How to use GlideAjax in on submit client script
KARAN24
Hi Team,
I have to do a validation on one variable called tax id ,if the tax id  does not exists in account table ,it  clear out the value, and is happening with On change client script.But it should not allow to submit the form.But form submission is possible.How can we validate that field on oN Submit.
Karan
13 REPLIES 13
@KARAN24
that should not be ideally the case.
if the validation fails you are clearing the value and making it mandatory; then how user can submit form with empty mandatory field?
Hi @Ankur Bawiskar ,
I guesss the issue is it is not waiting till we get response from the server side.
Karan
@KARAN24 , not sure if you go the chance to look into the response shared at the top, the same thing I have already mentioned
@KARAN24
Refer these links for workaround/solution on how to use Synchronous GlideAjax in onSubmit
How To: Async GlideAjax in an onSubmit script
Asynchronous onSubmit Catalog/Client Scripts in ServiceNow
