How to use window.location.href.contains() in script include?
Thousif S N2
I need to push field as mandatory based on the ui view . So i want to make the validation based on URL using  window.location.href.contains(). So if the url belongs to second UI page then make field as mandatory? But i am trying its not working ! so can any expert help
Thanks in advance
@Thousif S N
Would you mind marking my response as correct & helpful if I am able to resolve your query?
26 REPLIES 26
Michael Jones -
You can achieve this by combining both your client side code inside the UI action.
This article has a good example: https://www.servicenowguru.com/system-ui/ui-actions-system-ui/client-server-code-ui-action/
First you call your client-side validation and then pass to server side to execute.
Hope this helps.
If this was helpful or correct, please be kind and click appropriately!
Michael Jones - Proud member of the CloudPires Team!
I hope this helps!
Michael D. Jones
Proud member of the GlideFast Consulting Team!
Ankur Bawiskar
please use this and check in onload client script
function onLoad(){
// give here the value to search
if(top.location.href.indexOf('value to search') >= 0){
g_form.setMandatory('field', true); // give here the field name
Thanks its working on client ....
Will it work in script include?
If you require in script include then this should give you the URL in server side
I won't recommend this if something you can achieve just using client script.
var url = gs.action.getGlideURI().toString();
we have alreday a script include from where we are making a field as mandatory  .. so now i want push that based on the ui page
