how to write if condition for greater number in client script
Servicenow_12
Hi team,
I want to set assignment group using onload client script , if the number of users field value is greater than 200.
tried with below but its not entering into the loop.
var nou = g_form.getValue('number_of_users');
if (nou > 200) {
g_form.setValue("assignment_group", 'xyz');
Please help me with the right way of comparing the value with 200
PavanK960672992
Mega Patron
Hi @Servicenow_12 ,
Try below script on onload client script and active is true
function onLoad() {
  var num = parseInt(nou );
    if (num> 200) {
        g_form.setValue("assignment_group", '02826bf03710200044e0bfc8bcbe5d3f'); //add group sysid here
 If still not resolved try to add info message and check the value on number_of_users field.
or use display business rule and check and set it using onload client script
g_scratchpad.num=current.total_user;
11 REPLIES 11
Mohith Devatte
Tera Sage
Hello @Servicenow_12 ,
try this script .Use parseInt to convert it to integer and also set the sys_id of hte assignment group but not the name of the group
Make sure you are using correct back end name of number of users field
nou =parseInt(nou);
if (nou > 200) {
g_form.setValue("assignment_group", 'sys_id_of_group_record');
Hope this helps
Mark my answer correct if this helps you
Hi @Mohith Devatte ,
got stuck with if condition while comparing the value.sysid has been given for AG
