How we can initiate a flow from ui action?
jobin1
Hi Team,
How can we initiate a flow using ui action I tried below, but it's not working.
ui action script -runs on serviceside
(function executeAction(current) {
    // Set approval to 'Requested'
    current.approval = 'requested';
    current.update();
var ritmNumber = current.number;
  gs.log("inputsvalue0" +ritmNumber);
     var inputs = {
        ritmNumber:ritmNumber
    // Log the input being sent to the flow
   gs.log("inputsvalue" + JSON.stringify(inputs));
    // Start the flow
    var flowAPI = new sn_fd.FlowAPI();
    flowAPI.startFlow('request_approve_flow1', inputs, gs.getUserID());
})(current);
9 REPLIES 9
Hi Ankur
flow is published
so i need to use the provided script  in ui action script right?
after that do i need  do i need to add or modify anything in flow?
scope:
Basically once's the ui action clicked then the flow should trigger i tested flow using test option manually the flow is working
@jobin1
use create code snippet, get that code and add that in UI action
update your script with the correct inputs
We don't know your sub-flow is in global or some other scope and also the name of the inputs.
So you are the best judge here.
I just shared show the UI action script might look like, please enhance it further
I believe I have answered your question
Hi Ankur
i am getting  below log
       gs.log("inputsvalue0" + ritmNumber)
but json structure log is not coming for RIM its empty
@jobin1
what came in log?
You can just put the copied code snippet in ui action. That's it.
