I'm facing problems while testing Flow Designer using ATF? Any views on the best practices for tetsing Flows using ATF
ajay konduru
I'm facing problems while testing Flow Designer using ATF? Any views on thebest practices for tetsing Flows using ATF
Pradeep Sharma
Hello Ajay,
As of this writing, ATF support for flow designer UI is not supported.
- Pradeep Sharma
Hi Pradeep,
I see this was 11 months ago and was in reference to Madrid. Do you know if ATF support for flow designer is supported in Paris?
Thanks!
Hi.. I created ATF for Service Catalog with Flow Designer and it is working fine. Similar catalog with Flow Designer which calls Sub-Flow and it is not working as expected. I believe Sub-Flow is not getting called correctly. Is that expected? if yes, how to create ATF for item which has sub-flow in flow designer.
Ankur Bawiskar
Hi Ajay,
ServiceNow doesn't support ATF capability for flow designer. I checked in Orlando
There are no steps for this
you can confirm this by visiting this table
sys_atf_step_config.LIST -> Step Configurations
Possibly in coming version they may add some steps for this
If my answer solved your issue, please mark my answer as ✅ Correct & 👍Helpful based on the Impact.
