I'm facing problems while testing Flow Designer using ATF? Any views on the best practices for tetsing Flows using ATF
ajay konduru
I'm facing problems while testing Flow Designer using ATF? Any views on thebest practices for tetsing Flows using ATF
Repeat.
Pradeep Sharma
Hi Ajay - I hope all is well. Let me know if that answered your question. If so, please mark my response as correct so that others with the same question in the future can find it quickly and that it gets removed from the Unanswered list
- Pradeep Sharma
skesavan
Hi.. I created ATF for Service Catalog with Flow Designer and it is working fine. Similar catalog with Flow Designer which calls Sub-Flow and it is not working as expected. I believe Sub-Flow is not getting called correctly. Is that expected? if yes, how to create ATF for item which has sub-flow in flow designer.
