I'm having an order guide issue with mandatory fields
Blair5
On our order guide, there are 2 default items that get ordered every time. The first one (first tab) has 2 required fields and the second one (second tab) has 3 required fields. On the second one, the fields are set to mandatory via the actual variable. However, there is a certain use case where a user can submit the order guide without filling in these fields. So, when the support team gets the task the fields are blank. I am not able to reproduce this actual use case in our non-prod instances. The closest I came was to fill in one field and go back to the first tab, and then check out.
I tried setting the fields to mandatory using a UI policy, but the order guide can be submitted with out ever clicking on that tab. What am I missing? Is this a bug? Has this happened to others?
sreed
Kilo Explorer
So are the variables on the second task actually mandatory at the field level or are they being set mandatory by a client script?
Blair5
In production, they are set to mandatory on the variable. I did some testing in our DEV environment and set the fields to mandatory using a UI policy. (this allowed the order guide to be submitted without ever clicking on that particular tab - mandatory indicator was not shown)
I'm trying to reproduce this in the service now demo instance.
sreed
Kilo Explorer
We did have similar issues trying to set the variables mandatory via script but I dont recall having any problems with variables that were set mandatory at the field level.
Yes -- It's hard for me to reproduce that issue. However, it has happened on several occasions in our production environment. What did you do to remediate your issue?
