I need to get the voucher for CAD
01-08-2025 12:44 AM - edited 01-08-2025 12:45 AM
I have completed the CAD certification course and got the voucher but am not able to took the exam with that voucher later that voucher got expired (without took the exam). So I need to take the exam but how should i get the voucher again.
Thanks!
01-20-2025 01:10 AM
Hello @mania
Please raise a ticket in Now Learning. They will be able to investigate and assist you in correcting this discrepancy.
Here is the link to raise your case: Now learning help center
Hope this helps!
"If you found my answer helpful, please like and mark it as an "accepted solution". It helps future readers to locate the solution easily and supports the community!"
Thank You
Juhi Poddar
01-20-2025 01:13 AM
Additionally you can also drop an email at certification@servicenow.com
Hope this helps!
Thank You
Juhi Poddar
01-20-2025 12:21 AM
Hi @mania
There are 2 issues
- 1st , you are not getting the Voucher for CAD, for that you can log a now Learning case and team can help you.
2nd is the screen shot you shared if for Delta, means you aleady completed few mainline and now you need to give delta exam for same.
01-08-2025 01:01 AM
Hello @mania ,
You need to complete the training again in order to get the voucher, you might need to pay for this time.
Please mark my answer as accepted solution and give thumbs up, if it helps you.
Abhishek Thakur
01-08-2025 01:11 AM
Hello @mania
You will have to retake the course in order to receive a new voucher for the exam.
Thank You
Juhi Poddar
