‎07-03-2025 05:21 AM
I have just copied the filter conditions of a Service table in reference qualifier, now i need to include it in script include and then call it in Reference qualifier override, please suggest.
What will be possible script include?
‎07-03-2025 07:08 AM
Hi @Piyush Dwivedi ,
Actually this is not helping whatever you are sharing
we are trying to help you but the info you are sharing is not really helping.
you could have shared all these details like what you have done so far the scripts that you have used and some screenshots of configurations you have made and issue you are facing
this should not be taking this long and these many attempts in providing you the solution especially for a question like this
I would suggest you to to go through below blogs for on how to post question in community
Tips on asking Question On Community
10+ Tips for writing a quality community question
please don't post duplicate question when there is already a discussion going on the same issue and I have seen the scenario is same in other threads as well
Please mark my answer as helpful/correct if it resolves your query.
Chaitanya
‎07-03-2025 06:27 AM
just return the encoded query from the method, copy you encoded query and return the encoded query
example refQual method return "place your encoded query"
var refQualTest = Class.create();
refQualTest.prototype = {
initialize: function() {},
refQual: function() {
return 'PUT YOUR ENCODED QUERY';
type: 'refQualTest'
if this doesn't help in resolving/answer issue/query
please share your script include and encoded query will update you one what should be done
Chaitanya
‎07-03-2025 06:45 AM
Chaitanya
‎07-03-2025 06:26 AM
Sorry but you didn't share what you tried so far? share screenshots scripts etc
